Power Management & RAID5 array
18 Oct 2002
North Wales
Does anybody know, if I were running a (software) R5 array, if I could use power management safely in Windows2003?
What I want to be able to do, is shut off the hard drives when they're not being used, to save power. They won't be on and off all the time, it'll be more like over night, and during the day when I'm at work.
But, will sutting them down (i.e. going into standby) have an impact on the array?
Running software RAID5 is a bad idea in general... performance will suffer greatly.
Going into standby shouldn't have an effect though.
Well the CPU will have to calculate all the parity data. With a hardware Raid 5 card there is a XOR processor with (usually) onboard RAM to do all the calculations and therefore free up the processor and make the system faster.
The other advantage of a Raid 5 hardware card is that the array can be transferred into a different system. Your software array would be tied to that PC and that PC only I think.
Don't use powersave on the harddrives. RAID5 spreads the volume's parity data over the whole set of drives.
The only time when you could stop this from happening is if you unmounted the volume as the OS wouldn't see the volume anymore.
Scottland said:
But if the system is going to be soley used as a file server, it shouldn't have much effect?
It will mean that files are served more slowly than they otherwise could be with a hardware card.
