Power needed for overclocking 5870
4 Dec 2002
london
I have both adapters, 1 x 4pin molex to 6pin pcie and the (y splitter) 2x 4pin molex to 6pin pcie, currently using the 1 to 1 adapter and the 5870 runs perfectly fine at stock speeds but it dont like to overclock, if i used two molex to power a pcie do u think it will help with overclocks?
each molex produces 75w right? how much juice does a 5870 need?
oh the psu has 1x 6 pin pcie, but 5870 requires 2x 6pin pcie so have to use adapter for one of them, my psu is 580w crossfire certified.
I just thought there must be a reason for making 2 molex adapter versions, ie they would provide more juice.
580W crossfire certified? That sounds like the claim on my old Hiper Type-R PSU. If it is sTyle-R you have, change it and change it soon. They have a well deserved reputation for going wrong without warning and taking out some/most/all of your other components. I thought everyone was exaggerating until the day mine made killed my SSD by burning out a chip inside it.
Even if it's not a Type-R, the fact it only has 1 PCI-E power connector isn't a good sign. I would say change it for a quality 750W model and then you'll be fine to overclock it and even go Crossfire if you want to later (or go for a 600W if you never plan on crossfiring).
