Power off - boot problems
24 Oct 2005
Muswell Hill London
Hi Folks
Occasionally my PC gets accidentally shut down on the wall plug mains switch. When it does it's very reluctant to re-boot into Window's 8, it hangs on the motherboard splash screen then a black screen saying it can't find the boot drive, "select the right boot drive then re-start".
It takes multiple re-starts and usually entering the bios, then esc without making any changes before it will eventually recognise the "C" drive Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive and boot into Windows. The PC will then run, shut down and boot flawlessly until the next time it accidentally loses power at the switch.
Any thoughts a swifter recovery if it loses power again?
This is what I have:
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W)
Microsoft Windows 8 Pro 64-Bit DVD - OEM (FQC-05955)
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2)
PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply
Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW)
Corsair XMS3 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (CMX16GX3M2A1600C11)
Sapphire HD 6570 1024MB GDDR3 PC-Express Graphics Card
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD
Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM (WD20EZRX) HDD
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Corsair CO-9050004-WW / 120mm Dual Pack Fans
Many thanks
Al
