Hey guys,
Been looking at a computer that switches on fine all of the time but, increasingly, does little else... I get fan noise etc but no vga output or POST
You can't force it to power down with the power button, it has to be physically switched off at the wall!
Initially I though it might be the psu so that's been swapped out but the problem remains, now I'm thinking it might be the cases switch? I'm currently checking the memory as well - as you can tell, I'm all over the place with this one
Any ideas?
Cheers!
You can't force it to power down with the power button, it has to be physically switched off at the wall!Initially I though it might be the psu so that's been swapped out but the problem remains, now I'm thinking it might be the cases switch? I'm currently checking the memory as well - as you can tell, I'm all over the place with this one
Any ideas?
Cheers!
