Power Options - Balanced Vs High Performance?
4 Jun 2014
Hey guys,
I wonder if you can help me out. I use my PC for gaming mainly & below are my current PC specs:
OS - Windows 8.1 (64 Bit)
Power Supply - Thermaltake Toughpower 750w
HDD - 300gb
CPU - 3.2Ghz Intel Core i5 2500k
Ram - 8gb DDR 3
Video Card - 1.2gb nVidia GeForce GTX 570
I purchased this PC a few years back and it has been brilliant for me so far. I know that I'll probably have to upgrade some time in the future, but I'm trying to get the most out of it while I still have it.
Anyway, I have read a few things about setting the Power Options (in Control Panel) to 'High Performance'. It is currently on 'Balanced' and has been since I bought the PC. I was just wondering if you guys suggest switching to High Performance. Will I get less lag/better performance when gaming? What exactly will it change? Or should I just leave it on Balanced?
Thanks.
it will just run cpu at full voltage/speed a24/7
balanced will let the cpu downclock at idle in speed/voltage (web browsing)and full speed/voltage if needed,gaming ect
balanced is fine to use imo
+ wazza is on the ball the only time l use High Performance is for benching.
