power or wait
17 Nov 2010
UK
i would like to upgrade my computer, my memory is maxed out (all 2GB of it) during games or even when i just have quite a few programs open (i always do)
my problem is low budget £230 including dilivery
so i have found this
http://www.overclockers.co.uk/showproduct.php?prodid=BU-019-OP&groupid=43&catid=339&subcat=1803
which i might (just) be able to also buy a power supply
however i would prefere to have a i3
Intel Core i3 540 3.06GHz (Clarkdale) (Socket LGA1156) - Retail
Biostar H55A+ Intel H55 (Socket 1156) DDR3 Motherboard
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC)
but would this run on my ASUS 400w PSU
i do also have a spare one of these which i have only used for a week in a old machine
http://www.overclockers.co.uk/showproduct.php?prodid=CA-042-OK&groupid=701&catid=123&subcat=1709
any advice?
also i have only ever fully installed a AMD 939 cpu, so i would prefere bundles form OCuk
thank you
If you're using PSU now and not having any issues, changin mobo/RAM/cpu shouldnt really change it, only a newer gfx would really change the picture much, if you can put it together yourself, which isnt difficult, you can get this
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £119.99
Foxconn A7DA-S 3.0 AMD 790GX (Socket AM3) DDR3 Motherboard £54.98
(£45.82) £54.98
(£45.82)
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £33.98
Sub Total : £174.13
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £36.73
Total : £220.36
is that motherboard microATX?
i would prefere to have ATX, as my case is HUGE!!!
i would put it together myself if it was AMD PGA, more confident with that
also do you think that i should chage to my spare PSU as it is higher wattage?
Assuming you'll be adding what you get to the rig in you sig, if I were in your shoes with that budget, I'd look at getting a second hand Q6600 (G0 stepping) [£70] CPU and a 4GB DDR2 RAM (2x2GB matched pair). It'll offer you better performance than the Intel Core i3 540 and at a lower price. Comparison .
I wouldn't worry about fitting a new CPU, the fact that you've installed a CPU before should reassure you.
You could pick up an aftermarket cooler and overclock the Q6600 too. I would then think about upgrading your PSU but continue with the one you are using currently. I would stay clear of the OcUK Crusade 450W PSU personally.
the spec i have now will be moved into my sisters computer, just the parts i upgrade
she is using the AMD 939 i built a while back.
are you sure that a AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz will work with a 400w PSU, that is nearly 3 years old?
