power over USB
1 Jun 2005
Kent
According to wikipedia, USB can provide 5v, and up to 500mA, but how do i work out what this is in Watts?
I ask because for part of my coursework i have to determine what a set of HDDs could be used for, and i need to work out if one of the drives is suitable enough to be powered over USB, or if it would need an external power source.
current x voltage
(500x10^-3) x 5 = 2.5W
HDD drives use around 8-12W, so no is your answer I think.
current x voltage
Thanks for that, it appears the out of the 4 models of HDD in my question, 3 of them are under 2.5w (2 5400rpm drives operate at 2.2w and 2.1w when seeking, which is the max power requirements for them, and a 3600 rpm drive which max power usage is 0.75w when in the process of read/write)
Be aware that it says "up to 500mA" which may not mean that it can provide that at 5V
current x voltage
Or simply 5Vx.5A = 2.5W :p
BTW i've got a usb hub externally powered by a 11A 5V source, got 8 Laptop hdds via USB enclosures, works a charm :)
