Power plan?.
10 Feb 2011
I just got the 3700x CPU and in the power plan there are a couple of new changes then in intel which I was use to. I use to change it to High performance and leave it at that but now there are a couple more. Now its at default AMD Ryzen Balanced but in additional there are 2 more called.
AMD Ryzen High Performance AMD Ryzen Power Saver and the normal two plans. Is it safe to change to AMD Ryzen High Performance as if it just had the normal High performance only i would have just clicked that no questions.
Yes its safe.
Its the same thing as Windows Balanced and High Performance only with Ryzen specific optimisations because Windows sucks.
