Power plug for PSU
20 Jul 2009
So I got the OCUK case with 500w PSU and thought they come with a power plug but it never. So I have one which is 250v but on the PSU it says 220v
Will it be okay to plug this in to power the PSU?
It is 500w PSU, don't wanna risk blowing anything
You should check the fuse rating (Don't worry about the voltage rating), 5amp or 13amp should be fine. Assuming it fits you will be good to go.
