Power Point Presentation Help Please
5 May 2004
Northern Ireland
Hello - if this is in the wrong section I'm sorry. Could a kind don move it if required thanks.
I would like to know is there a way to record a macro in powerpoint that changes the font. I have tried but it does seem to work. Was just looking for any other ways. Thanks
Blackvault
The short answer is yes - just use the record button.
You can tidy up the following a bit - that should work
Code:
With ActiveWindow.Selection
    .SlideRange.Shapes("Rectangle 2").Select
    .ShapeRange.TextFrame.TextRange.Select
    .ShapeRange.TextFrame.TextRange.Characters(Start:=1, Length:=5).Select
    .TextRange.Font.Name = "Verdana"
End With
