Power problems GPU/PSU
21 Apr 2010
In need of some advice. My 1080TI PCI light has come on with a red light and fans have gone mad. This is the 2nd time it's come on. I've checked all the cables and plugs. The GPU is coming on for 7 years and my power supply is over 8 years old. It's a Corsair Rm850x. Could this be a GPU or power supply problem?
It could be either but I would be leaning more towards the GPU. I don't suppose you have access to a second pc that you could test the GPU in?
Does your pc have onboard graphics if yes take out the GPU and see if the onboard works ?
You signature says you have a 2080ti and a 12900k ?
