Power/pump issue?
26 Aug 2009
Two issues raise their ugly head from time to time.
- an infrequent one is that the PC stops responding, everything freezes still.
- the more predictable one is that if I cold boot the PC the pump often doesn't run, the only way I can get it to run is to tap the pump whilst the system is on - then it will spring into life.
I rarely turn the PC off to avoid the pump issue.
But when I have had to reboot, I've seen an error "Asus anti-surge was triggered to protect system from unstable power supply" and one about the CPU Fan cable which I now forget.
  • Asus MAXIMUS VIII IMPACT Socket 1151
  • Intel Core I7-6700K Processor (4 GHz, 8 M Cache, LGA1151)
  • Corsair SF Series 600 Watt 80 PLUS Gold
  • G.SKILL TridentZ Series F4-2800C14D-32GTZ 32GB DDR4 2800 MHz C 14 1.35 V Memory Kit
  • Pascal Titan X
  • 2 x Noctua NF-F12 IndustrialPPC 3000RPM PWM 120mm High Performance Fan
  • 2 x SSD
  • Bluray drive
  • EK Water Blocks EK-XRES 100 DDC 3.2 PWM Elite (incl. pump)
