Power recliner switch failure
3 Jan 2006
All along the watchtower
Hello, one of the switches on my reclining sofa has failed, I have swapped it with the working one from the other side and all seems good now.
I’m looking for a replacement, the model is kdh107-002 of which a few are available on eBay used and a couple of places new.
The new places are a bit of a rip off adding high delivery costs for example, but there are plenty on Amazon at sensible prices. I’m just not sure if they are interchangeable, mine has an in line box which I believe is a transformer for the usb, the ones on Amazon don’t but still have usb.
Does anyone know anything about these or enough to tell me whether to worry or not?
I appreciate this is a long shot
Thanks anyway
TBH at that price I'd just buy one and see. If you're worried, the used ones off eBay are more likely to be compatible than something odd Amazon.
I imagine the chairs wear out/break more than the switches, leading to spare parts being available from stripped dead chairs.
