Power reiner sofas... help!
22 Aug 2005
Kent
Hi
Looking at getting some new sofas and was considering power recliners with the battery packs. Before spending £5-6k on them though was looking for a little help & guidance.
1. Are power reclining sofas generally reliable? If they go wrong are they hard or expensive to repair?
2. Are the batteries worth it? Not near a socket so having them mains power means extension leads across the floor.
Do the batteries last long on a single charge? Are they a nuisance to remove, charge and replace?
Thanks!
Tjankyou
Battery packs add around £100 to the cost of each sofa. DFS claim theirs will do 150 reclines before needing to be charged... probably nearer 100 then. I'd say we'd use it no more than 10 times a week so we'd be looking at 10-15 weeks use before a recharge is due?
