- 17 Jan 2007
- London
Im starting to wonder if there is some sort of cartel involved in selling more and more powerful PSU's - allow me to explain:
Last week I tried overclocking my 6970 to see if I could get a few more FPS in BF3. I used the overclocking utility in both the ATI CCC and Afterburner, but I couldnt get ANY stable overclock - I could get into the game for maybe 30 seconds, but then Id get the driver lockup and recovery popup. I experimented with 100% fan and more power, but got the same results. Im pretty sure it wasnt temps, as with 100% fan the OC temp was actually cooler than my stock load temps! This made me wonder if my 620w PSU is struggling....
So, googled PSU calculator, input my details and it spat out Recommended PSU wattage should be about 650W.....interesting....
I started to browse OCUK for a replacement PSU, thinking this must be the cause, Ive had it for a few years so perhaps the capacitors just arent up to the job any more.... Had my eye on the Antec HCP 1200, as I thought this is the last PSU I want to buy, Id also like the future possibility of Crossfiring if I wanted to.
I hovered over the buy button, but then remembered - a guy at work has a power meter! Surely this will tell me if Im straining the PSU to its max?
I went home last night and plugged it in - was surprised at the kettle boiling took 2700 watts! But apparently, this is pretty standard - at least I knew the meter was working....
So I plugged it into my PC - about 150-180 watts booting up, which settled to something around 180. I fired up BF3 expecting to see 600 watts, or there abouts..... I didnt see the meter go above 300 watts, this was on Metro - so, I fired up a 64 player Caspian Border server, this would surely max out the PSU, right? Wrong - 330 watts AT MOST. Ive got a 2nd monitor so was able to see both my CPU and GPU at near 100% utilization - surely if there was a non-benchmark, real-world test to see how much power my PC is drawing, this is it, right?
This is totally baffling me, I cant explain why my power usage is so low compared to the recommended PSU wattage for my setup - surely something is wrong somewhere? I did wonder if perhaps some power settings in my BIOS myabe limiting the power draw, perhaps some 'green' features? If that were the case, why would I be seeing around 30-50FPS on Caspian and 70-90FPS on Ultra on other maps?
Totally baffled with this one...
