Power saving mode, Dead monitor?
27 Dec 2010
Hi, ill try explain this best i can to see if anyone has any idea whats wrong with my monitor.
Im trying to get my old monitor to work so i can have dual monitors, It is a LG W2243S, But every time i plug it in i get the LG Logo and then a message POWER SAVE MODE and then it turns black. It only has a d-sub connecter so im using a d-sub to dvi cable into my graphics card.
I have tried the same cable on my main monitor to check if it was faulty and it worked fine. Also tried a factory reset on the monitor.
Weird thing is i tried it on my dads computer and it does work but the screen comes up all pink but it is showing an image, Do you think its faulty?
Any ideas thanks.
Specs
i5 760
2x6870
8gb ram
