- 22 Sep 2010
- Torbay
Hi,
I have a Q6600 slightly overclocked to 3.0MHz and run in balanced mode on the power options which makes it run at 2.0Mhz.
My query is how good is windows 7 at bumping the speed back up when needed? THe reason I ask is I just unzipped 4 5GB files at the same time but according to cpu-z the processor speed remained at 2.0Mhz.
Should windows not bump the speed up for that as I assume it's quite a cpu intensive task? Or is it best to just run at the high performance setting all the time?
Thanks
Thanks
