Hi
i have the overclockers 4ghz bundle and was wondering what the cpu perfoemance should be set at in power options ( control panel )
i have set it on max performance , min cpu 100% .. max cpu 100%
can you drop min cpu to say 5% without causing problems or do you have to leave at 100% with overclocked systems ?
in core temp the processor will drop to say 2.4ghz and power to 43watts (on 5% min )but will go upto 4ghz under load....but when on 100% its at 4ghz , 130 watts all the time
cheers
karl
cheers
karl
