power suply unit
27 Jun 2009
this 800w psu is avalable from another well know retailer and i would like to know is thease specs any good it is a value psu but would it be able to handle say an am3 system with a nvida 975gt
Features
Silent and Better Ventilation
ATX 12V V2.2 Compliant for all Types of CPU and Mainboard
Automatic Fan Speed Control to keep balance and noise control
Separate 12V rail supply to mainboard and drives
12cm Green Silent Fan
Quad 12v Rails
CE & PFC Approved
Connections
20+4 Pin Main Connectors: 1
P4 4-Pin 12V Connectors: 1
4-Pin Molex Peripheral Connectors: 7
SATA Connectors: 6
6-Pin PCIe Connectors: 2
8-Pin 12V Connectors: 1
Floppy Drive Connectors: 2
A lot of people here will probably recommend the Corsair PSUs. Just a heads up. I don't know much about them, but never heard of that make.
yeah i havent heard of them aswell mate i really would like to know if any one has had experiance or if the specs are decent ?
i found this if this helps with determining weather or not itis a decent psu ??
AC INPUT: 230VAC 10A 50-60Hz Model 800THE
DC
Output
Max +3.3V +5V +12V1 +12V2 +12V3 +12V4 -12V +5VSB
20A 20A 15A 15A 12A 10A 0.5A 2.5A
I wouldn't trust it never heard of them
you want to be looking along the lines of corsiar, be quiet, ABS/TAGAN, silverstone, PC power and cooling, also antec do decent onces and a few others, also thermeltake do *some* decent onces but not all be careful
probably be better than that what you was going to get, OCZ have got some great some bad onces, not sure if that is one, check the reviews and customer reviews on that ;)
nvida 975gt is too badly mispelt for me to work out what you mean. OCZ will do you fine though.
Absolutely don't buy the one you've shown a photo of. Whatever price. Even at a fiver it would be crap value around the time it killed your motherboard, processor, ram and hard drives...
