- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
These Power Supplies from PC Power & Cooling offer amazing value for money and are reliable and efficient.
PC Power & Cooling Silencer Mk III Series 400W '80 Plus Bronze' Modular Power Supply - White @ £49.99 inc VAT
Building on the design expertise of its predecessors, the Mk III once again refines the Silencer lineup and defines the ideal power management solution for performances users. Engineered meticulously with only premium components, the Mk III balances the needs of server-class and IT professional standards, including 100% Japanese 105°C capacitors, continuous output at a demanding 50°C ambient temperature, and heavy-duty protection circuitries. Key features include a 120mm variable RPM fan for quiet operation, well regulated electrical noise and ripple, modular cable management system, 80 Plus Bronze-level efficiency, and comes backed by a 5-year warranty for ultimate peace of mind.
- Continuous output rated at a demanding 50¢XC ambient temperature
- Built with 100% Japanese low ESR 105¢XC capacitors for high reliability
- Single +12V rail for efficient power distribution in your system.
- Compliant with the latest ATX12V v2.3 standard for worry-free compatibility
- A large temperature and load controlled 120mm double ball-bearing fan for whisper quiet operation
- 80PLUS Bronze certified for up to 85% efficiency under real world operating environments
- ErP compliant for low power usage in standby or off mode.
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
- Safety Approvals: cTUVus, CE, CB, FCC Class B, TUV, CCC, C-tick.
Only £49.99 inc VAT.
ORDER NOW
PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply - White @ £59.99 inc VAT
Only £59.99 inc VAT.
ORDER NOW
PC Power & Cooling Silencer Mk III Series 600W '80 Plus Bronze' Modular Power Supply - White @ £69.98 inc VAT
Only £69.98 inc VAT.
ORDER NOW
PC Power & Cooling Silencer Mk II 750W '80 Plus Silver' Power Supply @ £79.99 inc VAT
The new Silencer Mk II 750W from the power supply experts at PC Power & Cooling is another leap forward for the legendary Silencer line. A thorough update, the new Silencer Mk II strikes the right balance between server-class industry standard topology and the cutting-edge of enthusiast computer power supply design. Built with industrial and professional power users in mind, key features of the 750W Mk II include a Single +12V Rail for maximum and efficient power distribution, a generous thermally controlled 135mm double-ball bearing fan for maximum airflow at near-silent audible noise levels, extremely tight and well regulated electrical noise and ripple, an ideal array of connector types for each wattage, and ultra-high efficiency, converting up to a full 88% of AC to DC power at typical loads. The Silencer Mk II Series is fully compliant with the latest ATX12V and EPS12V specifications. Power-packed and built to last with a 7-Year Warranty.
- 750W Continuous @ 50C (880W Peak)
- NVIDIA SLI Certified (Dual-GPU)
- 80+ Silver Certified (88% Efficiency); .98 Active PFC
- 135mm double ball-bearing fan
- Up to 90% (10dB) Less Noise per Watt
- +12VDC @62.4A (Powerful Single Rail)
- Rock-Solid, Super-Clean DC Output
- 4 x PCI-E and complete array of connectors
- Automatic Fan Speed Control Circuit
- 7-Year Warranty and Tech Support
Only £79.99 inc VAT.
ORDER NOW
PC Power & Cooling Silencer Mk II 950W '80 Plus Silver' Power Supply @ £109.99 inc VAT
The new Silencer Mk II 950W from the power supply experts at PC Power & Cooling is another leap forward for the legendary Silencer line. A thorough update, the new Silencer Mk II strikes the right balance between server-class industry standard topology and the cutting-edge of enthusiast computer power supply design. Built with industrial and professional power users in mind, key features of the 950W Mk II include a Single +12V Rail for maximum and efficient power distribution, a generous thermally controlled 135mm double-ball bearing fan for maximum airflow at near-silent audible noise levels, extremely tight and well regulated electrical noise and ripple, an ideal array of connector types for each wattage, and ultra-high efficiency, converting up to a full 88% of AC to DC power at typical loads. The Silencer Mk II Series is fully compliant with the latest ATX12V and EPS12V specifications. Power-packed and built to last with a 7-Year Warranty.
- 950W Continuous @ 50C
- NVIDIA SLI Certified (Dual GPU)
- +12VDC @83.4A (Powerful Single Rail)
- 6 x PCI-E and complete array of connectors
- 1 x 20+4 pin motherboard connector
- 1 x 4+4 pin CPU connector
- 1 x 8 pin 12V connector
- 6 x 6+2 pin PCI-E connectors
- 7 x molex connectors
- 12 x SATA connectors
Only £109.99 inc VAT.
ORDER NOW
PC Power & Cooling Silencer Mk III 1200W '80 Plus Platinium' Modular Power Supply @ £219.98 inc VAT
The industrial-grade yet refined Mk III 1200W is the Silencer Series’ most comprehensively powerful solution yet, and features a stringent 80-Plus Platinum certified rating for the highest energy efficiency possible. Engineered with only premium components, including Japanese 105°C capacitors and heavy-duty protection circuitries, the Mk III 1200W maintains continuous output at 50°C and efficiently delivers power through a single +12V rail. The Mk III 1200W also sports a new Dual Thermal Control System, a sophisticated operation that allows the PSU to switch between normal and silent mode seamlessly. Backed with PC Power’s complete confidence in reliability with an industry-leading 7 year warranty, this PSU offers ultimate peace of mind.
- 1200W Continuous @ 50C
- SLI and CrossFire Ready
- 80-Plus Platinum Certified (92% Efficiency); .98 Active PFC
- 140mm double ball-bearing fan
- +12VDC @99.5A (Powerful Single Rail)
- Premium Components with 100% Japanese 105°C Capacitors
- Modular Cabling Design
- Dual Thermal Control System: Normal and Silent Operation
Only £219.98 inc VAT.
ORDER NOW
- The 400w / 500w / 600w are made by Seasonic
- The 750w / 950w are made by Sirtec.
- The 1200w is made by SuperFlower.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
