Power Supplies Question
12 Jul 2010
Antec high current gamer 650 vs 750w.
My main Question is: why is the 620w more expensive than the 750w.
Details:
*620 runs a single 12 volt rail @ 48A
*750 runs 4*12 volt rails however each rail is capable of drawing 40A as long as total power is under 1Kw (overloaded)
I can't see why the 620 would be expensive under any circumstance.
A) the 750 can produce more power oviously.
B) the 620 is based on a seasonic design whilst the 750 is based on DELTA.
C)You can tie a voltrail to the CPU, & 2/1 other volt rails to the GPU easily outdoing the power outputted by the single 12 voltrail in the 620w.
Thoughts?
620w:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-148-AN&groupid=701&catid=123&subcat=
750w:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-149-AN&groupid=701&catid=123&subcat=
can't see anything obvious, only thing i could possibly think from the details you've put up is the fact its a seasonic model over the delta (not heard of them before).
