Power Supplies
Permabanned
15 Oct 2006
Scotland
As some of you know im on a budget right now, so once I buy the 7900 GTO 512MB, I need a new power supply. So I was looking at the OCZ ModStream 520w. But I was also looking at Hiper Power 530W 12v Low Noise PSU.
So which one is better to go for? Lots of oppinons needed and appreciated, cheers.
I'll add this of the spec of the Hiper:
Product Details
HPU-4M530 is also a member of the Type-M family offering true 530 watts, it's the wallet-friendly version of the new Type-R 530W series.
Features
Unique user friendly modular design to reduce excess cables.
Patented design device extension cables.
Supports ATX up to v2.2 & Intel BTX configuration.
Complies with all Intel & AMD CPU specification requirement.
Gold Plated connector, preventing rust & bad connection.
High efficiency APFC (Active Power Factor Correction). (N/A for US model)
Connects up to 4 SATA HDD + 8 other component devices.
Dedicated PCI-E connector.
EZ-Grip Molex connector.
Power Train
530Watt continuous output. (Peak Load 580 watts)
Newest ATX 2.2 with 2 x 12V connection
Chassis
Full 1.0 mm Japanese Steel
Complete Mesh Body
Cooling System
Active Thermal Controlled Circuitry
120 mm Long Life Fan
Power-Off Component Protection design
Power Delivery
Aviation Type heavy duty Enamel Modular Connector (Patent Pending)
UL/CE/TUV Grade Cables
Gold Plated Connector Pins.
Braided Power Cables.
EZ On/Off Connectors.
Stability System
Active Power Factor Correction. (N/A for US model
Main Features
Product Description Hiper Type-M HPU-4M530 - power supply - 530 Watt
Device Type Power supply
Form Factor Internal
Specification Compliance ATX12V 2.2
Dimensions (WxDxH) 15 cm x 14 cm x 8.6 cm
Weight 2 kg
Output Voltage +3.3, +5, ±12 V
Power Provided 530 Watt
Output Connector(s) 4 PIN internal power, 4 PIN mini-power connector, power 4 pin ATX12V connector, 15 pin Serial ATA power, 6 pin PCI Express power, power 24 pin ATX with detachable 4 pin section
Manufacturer Warranty 3 years warranty
I've heard of the Hipers having weak 12V rails. I've personally used an OCZ Modstream 520W which infact can peak at 600W and the cables that come with it are really thick and sturdy. Very impressed with it. I'd go as far as say it feels like a better quality kit then my Enermax Liberty and I reckon would easily outperform the hiper.
Alright cheers.
