Hi Guys,
My friend has given me his computer to repair as it was full of virus' and the 7900gs he had in it had gone (corrupt display etc). I rebuilt the thing and my friend had supplied me with a 8800GTX to replace the graphics card with. However, the 8800gtx would not fit his case so I have swapped it with my 8800gt which fits fine.
However, the PSU has now become a problem. The one that is in there is cheap and doesn't have a 6 pin PCI-e connector (its 3 pin). I need a cheap replacement PSU so was thinking of getting a Hiper 530W HPU-4M530 SLi Certified ATX 2.2 PSU as its only £40 with delivery and should hopefully power the components he has. His spec is as follows, let me know if this is enough:
ASUS m2v Mobo
AMD Athlon 64 X2 Dual Core 4600
4x 512mb corsair
1x 250gb HD
1x IDE DVD RW
Palit 8800gt
ASUS m2v Mobo
4x 512mb corsair
1x 250gb HD
1x IDE DVD RW
Palit 8800gt
) I did get it when i had a quad clocked to 3.8Ghz though. These Zalmans are terrific psu's and well worth a look. It is the best and by far the quietest psu i have ever owned. Try the 500/600w version.
