Power supply advice
8 Jan 2007
London & Dubai
Currently building the following system:
Silverstone TJ08-E
i7-4770K (possibly)
Gigabyte GA-Z87MX-D3H MATX
16GB Corsair Vengance (4x4GB)
160GB SSD (Windows 8 64-bit)
4x HDDs
Corsair HX1050 PSU
not too sure with regards to CPU but may go with a 4770K.
I already have a Corsair 1050W PSU, but would like something that was quieter.
System will not be overclocked & will most probably use the stock intel cooler.
Don't plan to game on this system, but would like to have the option to be able to add a high end GPU
What would people here recommend?
would like to keep PSU budget to around a £100
AX760 has Seasonic Internals.
RM750 has some other, not as great brand.
I'd recommend the XFX above, as it's Seasonic, looks great & cheapest.
The XFX 850 is also worth looking at if you want 2 GPU's in the future.
The XFX is @ a great price point, but I think a modular unit will suit me better as the Silverstone TJ08 is a rather small case
i got a coolermaster vanguard recently for a build, havent used it yet but they meant to be good
i think the RM would be fine just one maybe better to have fan facing up to let the heat out
