Power supply arcing
28 Dec 2004
Derry
I have an OCZ modstream 520W, for some reason the socket where you plug the kettle lead in appears to be a bit loose and has started arcing on an off, cutting the power to my PC completely, I've had it for around a year now so I was thinking of investing in a new PSU anyway. I'm after something quiet, reliable and because I'm a cable tidying freak it has to have pre-wrapped cables and be modular. Anyone have any suggestion? Thanks.
I've decided to throw the Modstream away, it's the third replacement since I bought the thing and I've noticed the warranty void stick managed to peel off when I was trying to get it into my case last time. Torn between the Tagan easycon and the 580W Hiper atm.
OcUK uses Tagan in their machines. Quality stuff with maximum compatibilty - Enermax have some compatibility issues with some boards according to one of the OcUK guys on the forums.
Personally, I use a Hiper 580 Type-R and I think it's excellent. People have mixed reviews of them though, some don't work out of the box and need RMAing (including my first). Mine now has never missed a beat and has excellent rails.
Turbo-Cool 1KW-Quad SLI
Developed to power ultra high-end graphics, the new Quad SLI version of the renowned Turbo-Cool® 1KW delivers 1000 watts (one kilowatt) of continuous, rock-solid power with a peak output of 1100 watts! Built with three independent AC-DC power modules, the Turbo-Cool® 1KW-Quad SLI is an efficient, amazingly quiet, EPS12V/SLI power supply with 66A (70A peak) of 12VDC in a form factor that fits most ATX cases. Truly, the ultimate computer graphics power supply!
1KW Continuous (1.1KW Peak) @ 50°C
Fits Std. ATX Cases (20” min. depth)
+12VDC Rails Total 66A (70A Peak)
High Efficiency with .99 Power Factor
Rock-Solid, Super-Clean DC Output
Amazingly Quiet Cooling System
Quad PCI Express Video Connectors
15 Drive Connectors (incl. 6 SATA)
EPS12V and nVidia SLI Certified
5-Year Warranty; Unbeatable Support
Each Turbo-Cool 1KW-Quad
For future proofing
how about another 520 Watt modstream, brilliant PSUs, and there very quiet, even my CNPS is louder :eek: and the cables are top notch, as well as the build quality and the layout of the inside. i got mine for a shave over £58 which is not bad value
my advice is go with seasonic (unless modulator is that important to you). Ive never tried tagan to say how good they are, althou they do have many good comments about them.
I used to have a Antec 550w and that was a good psu. Althou ive heard one ot two comments more recently.
ive tried a hiper and it blew up on me (520w) - scared me cos I just built a new pc. What a nightmare it would have been to send a whole pc back to o/c'ers - if the hiper destoried the whole pc.
also Q-Tec stay away from!! No idea why o/c sell them.
