- 6 Dec 2008
Hello all, it's me again bringing you another episode of 'Anderson's PC Problems!"
Jokes aside... yet again, my PSU keeled over and died. To paint the picture, I have the following specs:
CPU: http://prntscr.com/dbqrd3
Caches: http://prntscr.com/dbqrog
Motherboard: http://prntscr.com/dbqrtk
Memory: http://prntscr.com/dbqrzy
Graphics: http://prntscr.com/dbqs6k
This is what I had at the very beginning with no issues at all. GTA V was then released and I decided to get a new graphics card, an ATI Radeon R9 290x. This required a new PSU as it simply didnt have the right connectors plus I was concerned with the wattage not being sufficient as I have 550 with this Antec PSU that I have now.
Here comes the first problem...within about 8-9 months, the computer died on me. It would run fine without the GPU inside but fail to boot with the GPU in. I returned the card, they sent it back saying the card is fine, replace the PSU. I replaced the PSU - shockingly everything was working fine again. Several months later, BAM exact same problem occurs again. I didnt waste time sending the GPU and just replaced the PSU as it takes them about 2-3 weeks start to finish. Except this time, the new PSU didn't help boot the computer. So I returned the GPU to them. They this time just offered a full refund so I assumed the issue was the GPU causing the PSU's to fail. I had to revert BACK to the graphics card you see in the picture, AMD 270x or 260x I believe. Now, several months later, I leave my comptuer on over night (which is not unusual and not common either just depends on what I was doing the night before, IE, waiting for something to download.) And during the night, I wake up to a burning smell. I turned off my fan (not the computer fan, my actual bedroom fan thinking it was that...as it was only a cheapy one) and went back to bed. I woke up in the morning and could still smell the burning and I looked at the computer which was fine...and I opened case, couldnt really smell anything... so I just figured the bedroom fan had pumped out a lot... so I left it and started using PC. about 30mins in, the computer shutsdown without warning and refused to turn back on. That's when it dawned on me that again....the computer had issues....I open the case and look for any signs of burnt'ness and i see nothing, no smell really... a slight faint smell of burning....so I assumed it was the computer afterall..and so I gently touched the top of the PSU and BOY it was hot... couldnt touch it too long kind of hot. So once again, my PSU has died and from seemingly over heating.
My question is this.... I dont want to keep wasting time buying new PSU's if there's a fault elsewhere causing this issue. I'm seriously considering buying a new motherboard bundle and seeing how this goes? I don't know what else to do at this point... I know 100% it is not the GPU causing this because this is now my original one from years ago...and it never had problems in the years that I used it... I do/did have 3 hard drives connected this whole time, could it be a faulty hard drive? should i just go down to 1? I'm at a loss here guys, please advise.
