Power supply dosent fit ITX prodigy, any ideas?
Hi and welcome to the forums. :)
The Superflower Leadex Gold 650w is not a normal length psu at 200mm long. For a 650w unit that's a ridiculous length. The normal length of a psu of that size would be 150-165mm. Once you hit 750w they start to increase in length. How long have you had it? If you have had it for only a week or so then you may be able to return it and get a different one. My suggestion would be one of these:-
YOUR BASKET
1 x EVGA Supernova G2 650W '80 Plus Gold' Modular Power Supply £74.99
1 x EVGA Supernova GS 650W '80 Plus Gold' Modular Power Supply £71.99
The EVGA Supernova GS 650w is a 150mm long Seasonic built unit with a 5 year warranty and the EVGA Supernova G2 650w is a Superflower built unit and is basically the same unit you already have in a more normal 165mm length but with no tacky led's and a longer 7 year warranty.
max PSU depth 160mm, as quoted by Bitfenix. Not sure what you mean about the plate lol.
Even 160mm PSUs are difficult to get in, as there will be minimal to no room for cables to fit especially for modular PSUs. This is what I've gathered from the reviews anyway. Looks like your best bet may be a SFX power supply or a relatively short modular PSU.
OP, what is your spec? Just about any single gpu system will comfortably run on a 550w psu. This one while not modular is only 145mm long:-
YOUR BASKET
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
This one, also not modular and only bronze rated is 140mm long:-
YOUR BASKET
1 x SuperFlower FX 550W '80 Plus Bronze' Power Supply - Black £49.99
The Antec Truepower Classic 550w is also 140mm long, gold rated but not modular:-
YOUR BASKET
1 x Antec TruePower Classic 550w '80 Plus Gold' Power Supply £59.99
