PC crashed and failed to post, did the usual of manually resetting the BIOS using the jumpers, turned it back on and the power supply made a horrendous noise. Had my head right next to my PC so at first I thought it was the internal speaker (it's a similar high pitch, loud squuek/beep) but quickly realised it wasn't and pulled the plug.
Turned it back on without it connected to anything in my PC, and it didn't make the noise, tried again with it connected to an old motherboard, and it does.
Anyway, it seems quite obvious that the power supply is buggered. Problem is I don't have a compatible power supply to hand so I can't boot and see what the damage is.
My worry is that it was connected, with the power on, for a good 5/10 seconds, anyone hazard a guess if there'll be any damage to my other components from it?
It's a Corsair HX520.
