Hi all,
Could do with some tips about how to connect a second EPS12v cable (the one for extra power to the CPU) to the power supply (NZXT Hale90 750w) I'm expecting, if it's possible at all.
That power supply only comes with one such cable, and the motherboard (MSI Z87 Mpower Max) has two connections for them. So for the next build I'll get an 850w that has two of them.
Now, I know the mobo and cpu should work okay with one of those, but given the mobo has two connections and using both is meant to provide a little more stability when overclocking the CPU, it would be nice if there was a way to rig up a second cable to the 750w power supply that I've already purchased.
Any ideas?
Any ideas?
