Power supply fan.
1 Aug 2006
I have an Antec truepower 750 power supply the fan become very loud so I replaced temporary with normal fan but now I wish to go back to silent running.
Will any 120mm PWM fan be OK?
Maybe I can use a resistor slow down current fan.
What are your thoughts please.
I can not seem to find a original replacement.
Thanks.
any pwm fan should be fine.
my psu just started rattling as well grrr!
I think it's only a year old as well so they must use the most rubbish fans possible to save 3 pence or whatever it would cost for a fan with decent bearings
Might not be a problem with the fan design, just sometimes hardware fails prematurely.
Buy any decent *silent* PWM fan with a high CFM and it should do the trick.
If you have a faulty PSU within the RMA/Warranty period though, i'd be inclined to suggest sending for a replacement.
