Power Supply for WD Mybook
23 Nov 2005
London
Hi,
Was wondering where i can get a power supply for a WD Mybook Essential 2.0. The WD website only sells the US version and google didnt help much either.
if its anything like my mybook ver1.. all you need is a 12vdc 2A supply with + on the inner and - on the outer of the connector..
im guessing yours is the one with the light in the shape of a circle at the front..if it is then i think they do use the same type of power supply since on WD site the same power supply is listed as a replacement..
so what exactly should i be typing into google..had a look at currys earlier they had some universal adaptors but looked as if the plugs wouldnt work with the HD.
think thats gonna be the main problem..finding one with the a connector the correct size..not gonna be able to buy that off the internet..
