Hi guys first time on here, i have fitted a "Sapphire x1950pro agp"graphics card which needs a power supply with 30amps sustained on the 12v rail,so i bought a corsair 620w hxuk(3x 12v rail with 18a per rail) it will not start the pc in any shape or form , my mobo is a winfast nf3250k8a i thought it was the psu at first so got a replacement and still the same afer doing the paper clip test the psu seems ok . corsair say the mobo is not compliant!! the mobo is a 754 socket for an athlon 64 3000+ cpu ,what i want to know is if i leave my old 550w psu in the pc
plugged into the mobo,and take wires off the green and black to the green and black on the 20 pin plug on the new psu, the pc will start up and also power up the new psu can i then use the new psu to power the graphics card,etc thus run two psu,s i am finding it difficult to find a mobo that is compatable
surely you would have thought the corsair would do the job i thought it was tip top gear !!
