- 16 Apr 2014
Hello,
I recently brought the leadex superflower gold 850w from overclockers and it looks great, however the plug supplied is a 2 pin (rounded) which doesn't work in the UK (3 pin rectangle).
The plug itself says on it 16A 250V~
My question is, Can I change it with a plug that I already own which is a 5A 250V~ (currently being used in my old PC)
If I am correct, the "##A" is just the type of plug so this other plug should still work in the same way regardless of its model?
Thank you for your time.
