- 27 Dec 2006
Hi Guys
Going to be building a system with the following spec:
EVGA 680 SLI
Intel E6600
OCZ XTC 2Gb DDR2 6400
EVGA 8800GTX 768Mb (buying elsewhere though so cannot step up
2x SATA WD RE 160Gb 7200rpm 16mb (RAID0)
*Both of the above in internal Icy Box enclosures*
1x Seagage SATA 80Gb
NEC 16x DVD burner
Samsung 52x CD burner
Thermaltake Tsunami Dream
Dell 2407WFP A03 24" HDCP Display
So my questions would be...
a) Is there a decent PSU that would happily power the above system + a couple of cathode lights and USB devices for around £100
b) will the 8800GTX fit if i remove the HDD bay of my Tsunami dream
c) any improvements to choices of components?
Edit: i will be overclocking the GFX and the CPU
EVGA 680 SLI
Intel E6600
)2x SATA WD RE 160Gb 7200rpm 16mb (RAID0)
NEC 16x DVD burner
if youintend to get a second gfx card and go sli then you will something with a higher output
