- 31 Mar 2012
This a previous thread that I created to gather some advice: http://forums.overclockers.co.uk/showthread.php?t=18388609
These posts are from my friend. We're trying to find advice on what we need, all that's left is for someone to reply to this post.
Post 1: hi guys thanks for the advice, just to clear things up our budget is between £80-150.
i actually have a power supply thats just laying around from a system i bought here which later i upgraded.
the power supply is listed as OcUK Value 500W PSU
and on the side of the psu it says ATX p4
would this power supply be enough? if not please take into consideration of our budget
Post 2: and here are the recommended specifications for dota 2
* OS: Windows® 7 / Vista / Vista64 / XP
* Processor: Intel core 2 duo 2.4GHz
* Memory: 1 GB for XP / 2GB for Vista
* Graphics: DirectX 9 compatible video card with Shader model 3.0. NVidia 7600, ATI X1600 or better
* Hard Drive: At least 2.5 GB of free space
* Sound: DirectX 9.0c compatible sound card
If anyone could reply and help us or give any advice, it would be very appreciated.
Thanks.
Thanks.
