Power supply issues - PSU tester?
26 Feb 2004
Hampshire, England.
Hi guys,
I suspect I'm experiencing psu issues but I want to be certain! I realise I can swap out the suspect unit but I remember reading a while back that as well as using a multi metre, there are various psu 'testers' on the market - most of which are under a tenner :p
Just wondering if its worth? I'd use it now but it would seem like quite a useful thing to keep in the tool box?
What problems are you getting?
The usual; random freezes, reluctance to start (the first cold boot fails, the second one is fine!), windows taking an aeon to load - with various 'not responding' messages along the way...
Its the psu that came with the case, a generic looking p4 500w joby, and I have a e7500 in it now :)
To be honest, if I was you I would march my PSU down to an independent computer shop and ask them to get out their PSU tester and try it :p I think most stores would be willing to help - If the PSU is kaput they have a chance of a sale, and if it's not then good times :p
I have one which came as an extra from the etailer when I bought my seasonic PSU. For the sake of a bit over £40 I would buy a 450w 80+ PSU from a branded maker and get rid of the generic one.
Thanks guys! I'll definitely try another psu (a decent one!) and would always use a branded one for my own setup, but the machine in question is at work...
Think I might still get one of those tester thingy's, one with an lcd panel probably, they look pretty useful, if they work :D
They're not really. Might tell you if it comes on and the voltages are somewhat in the ballpark but it tells you nothing about ripple/regulation etc.. i.e the things that really matter when in use, even the motherboard sensors fail dramatically at this and can only really be a good indicator when somethings REALLY off.
