Hi,
Just in case it helps before I begin here are specs of my pc (bought a ocuk system (complete system they build (Titan Goliath) just over a year ago)) - intel core i7 920 @3.4ghz, gigabyte EX58 - UD3R mobo, 6gb DDR3 Corsair Xms3 Ram, XFX 4890 1GB Gpu, 1TB Seagate Barracuda SATA II HDD (I assume sata 2), Corsair TX 650w PSU, Windows 7 Home Premium 64 Bit, etc.
Ok so what my problem or what I guess could be/become a problem is this. I turned on my computer this afternoon, everything was fine as usual, used it for about 40-55mins, I heard a funny noise, possibly scrapey noise, then I smelt a burnt smell coming from my comp, not hugely smelly but you could smell it, my comp seemed to be working just fine still but I immediately safely shut it down, powered everything off. Next I gently moved it onto it side opened case up, dusted (I do dust inside the case as often as I can once every 2-4 months) everything, assuming it was my GPU I removed it and smelt it, it didn't smell of burnt smell much (bear in mind with the fans probably blowing the smell around the whole inside smelt a little. I gently unhooked the power supply (case is the lancool dragonlord k-62) and smelt the underfan area bit, I'm pretty sure this was the source of the smell.
The things I don't understand are why the computer was still running fine after I smelt the burnt smell, surely if the psu had a problem the computer would power off instantly due to not having power go to it, unless perhaps it was the psu's fan going, I don't know I'm afraid I'm not the most computer hardware knowledged guy. The questions I ask are do you huys know what the problem might be and what do I do next, I am tempted to try it tomorrow afternoon as perhaps it was just overheating due to the fact I have used it a lot over the last few days, but I won't do anything that could reck my pc without your advice first.
Thanks for any help/advice/suggestions in advance
I'm worried about my pc, I hope this isn't a major prob but you guys know about this stuff.
Thanks again
Mark
Thanks again
Mark
