Evening All,
Have problem which I believe may be due to the power supply but just want to check to see what you guys think before I replace it.
For a while now, when I unplug my computer from the main supply and then plug it back in and when I press the power button if turns itself on for a split second (Fans start to spin, LED's come on etc etc), then turns its self back off. It take about 20 presses of the button till it finally powers back on and boots up. It is fine after this when I shut the PC down and restart it. Its only when then mains power is removed.
But now when I go to play a game, the game will start to load and then the computer dies instantly. So I'm thinking that when a game starts the GFX card goes into 3d mode and therefore draws more power which the power supply can't handle and then it shuts itself off. When it is on the desktop it is fine.
The specs are:
Intel Core 2 Duo E6750
Corsair PC2-6400 2Gb Ram
Abit IN-9 Motherboard
Gainward 260GTX
2 Hardrives (250GB & 500GB)
Blu-ray drive
Corsair 600Watt power supply.
The powers supply is nearing 4 year old now. Any think else I could try or is it a case of replace the power supply and it'll be fine.
Cheers for any help you can give.
The specs are:
Gainward 260GTX
Blu-ray drive
