Power Supply Question
11 Aug 2007
Hi
I'm thinking about upgrading my graphics card on my computer, but what is the lowest wattage power supply I would need to run my system (see signature) and a 4850/4870?
Thanks for your help.
About 500w, probably work with less but why struggle with the minimum if you're in the market to buy a new PSU? What d you have right now?
your better getting a higher powerred psu than you need, they run more efficiand that a psu that is oan load constantly, plus, you your system only needs 300watts and you have a 800 watt psu, you will still only use 300watts, so it leaves room for the future :p and wont have such a strain on the psu which will in turn last longer and run cooler :)
something like this, cant really go wrong..
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS&groupid=701&catid=123&subcat=1084
If it's that **** then it's a good plan to upgrade it anyway. the high performance GFX card (and the rest) likes smooth, clean power so get yourself a decent PSU - worry less about watts and more about build quality. A good 500 would do, no harm going a bit higher output if you have the money. Don't sacrifice quality for output.
Agreed. I would also add another 2GB of RAM, they're cheap as chips these days.
The zalmans are fantastic, the guys on the forum told me to go with one and it worked perfect in a 4850x2 build.
the zalman 650 would be a good future proof PSU
your better getting a higher powerred psu than you need, they run more efficiand that a psu that is oan load constantly.......(SNIP)
People keep saying this and there is no logic that I can see behind it. an 80% efficient 500w psu will use the same amount of power at 300w that a 1000w 80% efficient psu.
Power is power, affected only by power factor (or effiiciency in friendly terms)...
Unless years of electrical training decieves me ofc, or theres leprechauns involved.
Good 250W PSU would be enough for your current config but no such available so would have to be satisfied with around 350W PSUs.
With 4870 peak draw would reach to mighty 220-230W.
Corsair VX450 is good for nearly any single GPU PC.
Even crap PSU would power 95% of gaming PCs because PCs don't consume as much as loudest yellers think.
Besides I haven't yet seen innards shot of Zalman which would include highest quality capacitors.
Efficiency isn't flat line but curve with drop especially in low load end so assuming similar designs that 1kW nuclear power plant would waste more power because with 500W PSU load would hit directly to range of highest efficiency. And especially during 90% time when PC is on (idling, web surfing) efficiency of later would be crappy.
And power factor doesn't have anything to with with efficiency or consumed power, just only with how much there's reactive power increasing apparent power.
The 1000w/850w are Enhance designs: http://www.silentpcreview.com/article834-page3.html
The 750w/600w/500w are based on the FSP Epsilon but instead of just getting them rebadged they got FSP to tweak the design enough to solve the ripple problems: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=30
