Power Supply Question.
12 May 2010
West Bromwich
My PSU is rated at 850W. Does that mean it is permanently using 850W, or does it mean it has the capacity to pump out a total of 850W as and when required?
Cheers.
So just to clarify, If I only connect a few components, that use a total of say 500 ish watts, thats all I'll be using,
Not a permanent 850 (wasting 350 watts)
A psu only draws enough power as and when required, as long you have enough overhead so it's not powering to many components so it's at full whack all the time.
