Power supply question
21 Oct 2002
Behind Melmac, ssshhhhh
First off my machine runs fine, been playing Dirt Showdown (cheers pgi :) ) crysis 3 and farcry 3 no probs all maxed, but as you can see from picture above my 12v rail only shows circa 8v is this just a glitch of should i be more concerned, going to boot into bios and see what it says there as soon as TR downloads :)
If your going to measure your power supply in any way always use a voltimeter. Software isnt reliable or accurate,
cheers for that :) i'll leave it be then as it's working fine and i can't be bothered to get the metrahit out the van, might do if/when i upgrade case :D
Edit: steam lost connection so checked bios on reboot 12v :rolleyes:
