Hi there, I'll share system specs first before I detail my potential problem:
I7 2700k 4.5ghz 1.31v, cooled by coolermaster seidon 120v
Gigabyte Z68xp-UD4
8GB Corsair vengeance RAM
R9 290 cooled by corsair HG10 and Corsair H80
Corsair TX850M
Kington 60GB SSD
WD 1TB
If I've missed anything off just let me know.
Now for the advice part, I've been thinking lately that my PSU is failing, for this reason I keep getting strange burning smells in the room where my PC is located.
Coupled with this is the crazy +12V readings I'm getting in speccy and HWinfo idle it is normally 11.926 but I get drops to 11.141 and idle 11.926 degrades by doing nothing.
I can cause the massive drops by opening tabs in firefox and even something simple as just typing, accompanied by the drops is a drop in fan speed or a pump speed I'm not sure which though but the fluctuating noise can get annoying.
I've attached a pic for you to gander at and ignore the CPU temps for some reason the C states aren't kicking in so the CPU is stuck at 4.5ghz when it should only be the turbo speed.
To summarise would you say the motherboard is bad or is my power supply now confined to the scrap heap?
Cheers
Well done for checking you spelt the thread title correctly Ian, jeez louise.
Gigabyte Z68xp-UD4
Corsair TX850M
Kington 60GB SSD
WD 1TB
Cheers
