Power Supply Recommendation
14 Jul 2008
Can anyone recomend a decent modular power supply, nneds to be 880 watt upwards, price up to 150ish, and as modular as possible, don't want a pile of attached cables as well as plugin ones, just the basic motherboard power and rest as plugin, and it does not need any boy racer lights :)
Thanks
Thanks
http://www.overclockers.co.uk/showp...d=123&subcat=1088&name=Antec Quattro 850W PSU
Just under the required wattage (though I VERY much doubt you will need anything more powerful than that).
Thanks, I'm not really an Antec fan, had 2 of them puff out some after a few months years ago, so I avoided them since.
I have an Enermax Galaxy at the moment, but it is fitted with way too many cables as standard and you just end up with an untidy bunch folded up.
I wouldn't look at past experience to determine your next buy with power supplies. Because the power supplies are very rarely made by the company it is branded by, instead, a seperate OEM. These are made by Enhance, and it is a brilliant power supply.
What exactly are you trying to run?
