Power supply requirements for nvidia 780 GTX
16 Sep 2009
Loogabarooga
I currently have a 780 GTX in my PC and I am thinking of upgrading to a 980 ti and building a second PC for my daughter and using the 780 GTX.
Any recommendation of wattage for the power supply please? I have a 850W corsair in mine and will be building a mini ITX one for my daughter. I also like to have more than enough power.
The resale value of my 780 GTX would only get me a brand new 960 so I might as well keep hold of it.
I have a budget of £60 to £90 for the PSU.
£60 will see you a 650 watt superflower psu. Thats the way i would go. A good 500 will do you fine however nothing wrong with having a little head room for upgrades later.
You want 600w as a comfortable minimum. A 500w or 550w would just about do it but leaves you none to little overhead. My pc has a peak power draw of 452w at the wall and hits a max of 422w while gaming. That is too close to a 500w psu's max power for my liking. If you already have a 850w Corsair then use that.
