Power supply should I go modular?
Modular only helps if your current rig leaves a lot of leftover cables from your PSU lying out and your case isnt built with good management or hasnt got a lot of space to hide the unused cables without sacrificing air flow.
Basically modular isn't essential and if your not worried about a possibly untidy or slightly hotter build then stick to a wired PSU as it will keep price for the same watts down aswell
Another good non modular 750w supply http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-XF&groupid=701&catid=123&subcat=1497
The case im going for is Lian-Li PC-7FNWX Black Mid Tower Computer Case which does have cable management features.
I think ill stick to regular psu then as any unused cables can easily be stored away
Just seen theres a modular version of the power supply ive selected for an extra £10.
Will it be the exact same quality but just modular?
I cant find any reviews on the modular version probabbly because its the exact same with the option to go modular?
For the extra £10 should i get the TX750M ?
Its brand new out so no reviews - but they said its based of the version i linked but just modular.
Im really skeptical to buying it seeing as theres no reviews out for the modular version
Should be exact same only not hardwired, buy it as ya shouldn't have an issue with corsair and if ya like the results of the reviews ya read it'll be fine
My main problem would be it being louder than the original version the modular version must be brand spanking new as I cant find it mentioned on any other forums Just found the fan is 20mm smaller than the non modular version
Can highly recommend the PSU in my sig. Had it almost three years now, utterly stable, silent, best PSU I've ever had. Would never buy non-modular again.
