Hi,
I have just bought the Cataclysm Deathwing from overclockers.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-170-OE&groupid=43&catid=2040&subcat=
- Case: BitFenix Shinobi - Black
- Power Supply: OCZ 700w StealthXStream II
- CPU: Intel Core i7 2600K 3.40GHz overclocked to 4.40GHz
- Motherboard: Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard
- Cooler: Xigmatek Dark Knight CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB HDD + 30GB SSD
- Graphics Card: GeForce GTX 580 1536MB GDDR5
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
I also went for a 30GB SSD upgrade to bang the OS on!
My question is that if i would like to upgrade this with another GTX 580 will my PSU handle it?
I am not sure if i would need another GTX 580 for Battlefield 3? However i thought i would make the questions as im sure some point in the future i will buy another to SLI.
Open to any suggestions for any part of the rig aswell!
Thanks!
Thanks!
, might be worth waiting till you can afford a 60GB / 120 GB so you can at least get a few games on there as well.
