I've recently upgraded my HTPC, with a new Gigabyte F2A85XM-D3H AMD A85X motherboard, with an AMD A8-5600K Black Edition 3.60GHz CPU. there's an integrated graphics on the CPU, so the only other things i have in the case are 2x HD, 1x SSD HD, 1x Blu Ray player and 1x PCI sound card
this all went in my existing HTPC case which is an Antec Fusion HTPC Case - 430 Watt PSU
it works fine and there's no stability problems but i've noticed an occasional buzzing / high pitch noise from the Power supply every now and again. i'm wondering if it's sufficient to power the new setup or not?The manual for the motherboard seems to suggest 500W or above, but not sure if thats only really to cope with expansion and growth?
one other thing is that the motherboard has an 8 pin ATX 12V connection as well as the normal big 24 pin connection. the PSU only has the 24 pin and then an additional 4 pin ATX 12V (the old board had a 4 pin socket for that) so i've hooked them both up, but wondering if there's any problem with only having a 4 pin ATX 12V connected to what is an 8 pin connection on the new motherboard?
