- 9 May 2005
I used to run a rig with 2 power supplys and obviously for the one that wasnt connected to the mainboard had to have the 2 wires modded together so it would start up.
Like a total unthinking noob I cut the wires real close the the 20 pin plug and now want to use the psu as the main power source, so my question is what would happen if I just plugged it in as it is with the 2 wires still modded?
Im guessing that probly wouldnt be the best idea and my only option is to seperate the wires again and put them in there original connecters, as I have cut the wires real close to the plug its going to be easier said than done.
Would I be right in thinking I could just cut myself some wire off of a old psu and give the 2 wires some extensions, would I need to use the same coloured wire or are they all the same type?
Any help would be great
