Power supply with short cables?
Permabanned
15 Dec 2008
As above guys, I have a Fractal Designs Node 804 which is an awesome case but being built for mATX boards it can get quite crammed.
My current Super Flower 750w has cables that are too long ( Not to mention a pointless hardwired second CPU cable :rolleyes: )
I need a PSU that has nice cable quality ( i.e cables with nice braiding ) and has short cables.
Is there anything about?
Most PSU's wil have cables that are of similar length as what you currently have they are designed to be compatible for multiple scenarios(mATX/mid tower/full tower cases)
By the sounds of it you have a non modular PSU,any modular PSU will make a world of difference for you as you will only have to plug in the cables you require,which in turns will take up a lot less space.
There are also PSU's designed for for small form factor PC's that are smaller and come with shorter cabling.They are designed for lower power systems tho so your choice is extremely narrow considering your hardware and power requirements.
The only one i can see that would be at all suitable isnt even out yet but is on pre-order http://www.overclockers.co.uk/showproduct.php?prodid=CA-381-SV&groupid=701&catid=123&subcat=2283
Outside of that,when it comes to standard PSU's the Superflower Leadex gold range are fully modular and have CPU and ATX cables that are shorter than the vast majority of quality PSU's(for most this could be a problem for you tho could be a bonus)
