Power Supply
Permabanned
15 Oct 2006
Scotland
On the OCZ 520W Modstream I was looking at the box, I have this installed, but im wondering on the box one of the pictures has the actual modular cables neon blue. I know the fan has a Blue neon but is it a different model that has the neon blue cables?
titaniumx3 said:
They're probably UV reactive cables, so you'd need UV cold cathode lights in your case to illuminate them.
Where can you get them from, OcUK have them?/ how do you install them? do they just clip on around the cable or something? / how is it powered?
212 said:
Yeah, they do look pretty though!
Are the cables really stiff with the Modstream?
Well they are quite stiff but they are really tidy, I mean my system has hardly any wires, if you count the SATA cable and the floppy + hdd cables, thats it. The power supplies usually leave wires everywhere. The case im getting btw is the Thermaltake Soprano with the window.
Also my computer is running silent, and I mean silent, I can't actually hear much. Just the fan from the CPU I think but its ultra silent. But yeah the OCZ 520W Modstream is really good if you ask me.
